Could use help from the code hackers
Old Oct 11, 2002 | 09:51 PM
  #51
funstick's Avatar
yeah the whole confusing map value should be chnaged to reflect actuall ecm readout. if the ecm is seeing 100kpa then the ecu winbin file should indicate 100kpa etc etc etc. i must have overlookd something in the code. sorry about that.im still learning assembler its a bit of a pita to get started and to make matters worse im learning iintel and motorola so ive got alot going on in my head all the time. anyways ill update a ecu if you dont know how, which i doubt. it would be a good change and certianly less confusing.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
