Should the knock sensor be replaced?
Old Oct 11, 2002 | 08:38 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
The car in question is a 86 trans am that came with a TPI 305. Now the car has a 383 in it should the knock sensor be replaced or is it okay to use it. Ive heard that some 350 have a different part # for the knock sensors used in them.
Old Oct 12, 2002 | 12:11 AM
Morley's Avatar
Replace it with one for a 350.
Old Oct 12, 2002 | 02:31 PM
Guest
Guest
Posts: n/a
Does it work right? I have a 305 sensor on my 350 and it works fine. There was a resistor in the box, its something like 100k ohms, I was supposed to install it in the wire I guess, never did. Didnt feel like cutting a wire to put an exposed resistor in it for a universal type part.
Old Oct 12, 2002 | 02:47 PM
Morley's Avatar
The way I understand it the walls in the 305 are thinner so the sensor isn't as sensitive, you need a 350 sensor that is calibrated for the wall thickness in order for it to operate correctly.
db057
Aug 22, 2015 08:17 PM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92purpz28
Aug 11, 2015 02:30 PM
gwade12
Aug 8, 2015 08:17 AM
