727 running 749 code ??
Old Oct 20, 2002 | 08:52 PM
funstick's Avatar
i ran across a few 727 ecms this weekend ( i know what a lucky bastard) and i was wondering if the ecms are the same except for the connectors shouldnt you be able to run the 749 code ?? im just wondering if anyone has a good 727 pinout chart and if they are the same pin for pin ?? ie pin b1 is pin b1 ?? any ideas thatnx a bundle.
Old Oct 20, 2002 | 09:15 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
A 727 is in all tense and purpose is a weather tight 730. Its not a direct pin for pin (730 to 749, but its close) but I have heard of people using the 730 with the $58 code. I have not done this myself, I went straight to a 749 and repinned to match the SyTy harness.
Old Oct 20, 2002 | 11:14 PM
funstick's Avatar
could you perhaps throw me an email addy for someone who has done this ??? off list i would like to ask about the pin changes if anybody out there knows for sure. thanx man .
Old Oct 21, 2002 | 11:26 PM
funstick's Avatar
ok i figured out the pin changes. thanx for the help. i found the info over at the gmecm site. it looks like they just split the connectors.
Old Oct 21, 2002 | 11:54 PM
Boxeat2469's Avatar
So for me to run a setup that is speed density plus can recognize boost, I can use the 749, 730, or 727 ECM? Also, what MEMCAL would I need? Any possibility of reusing my 1989 MEMCAL from the 165 ECM? Any possibility of just repinning a 165 ECM and using a MAP sensor with the$58 code?
Old Oct 22, 2002 | 02:50 PM
funstick's Avatar
the 749 730 727 all use the same mother board and pretty much identical board population. the 165 does not. your memcal wont work. as for anything else yes the 749 730 727 can use the $58 code. as for the 165 you best hope is the 808 code or swap and repin to a 749 730 727.
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
squiggy2
Aug 9, 2015 09:30 PM
