Timing spikes to 90 degrees when downshifting
Old Oct 23, 2002 | 11:45 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I did a tf head and cam swap and after words the car does ok from 0-60 but from the 4th to 2nd downshift the timing spikes to 90 degrees and I get max retard. I think 30 some degrees leaving me in the hole. What can cause this? Maf maxing out all of a sudden? My maf does max out at 4000 on the 0-60 run but no side affects. Just when downshifting.
Old Oct 24, 2002 | 10:50 PM
funstick's Avatar
please email me a copy of your bin. maybe a bad value slipped in there. the throttle is closed the load is low. check the 0-16 gram area of the timing table at the aformentioned rpm range.
theshackle
Sep 17, 2020 08:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
bamaboy0323
Sep 3, 2015 06:07 AM
cstrobel65
Aug 15, 2015 10:19 AM
bamaboy0323
Aug 15, 2015 07:20 AM
