305 TBI auto bin compare, interesting
Car: 91 Red Sled
The ANTT and AXKT are both 305 TBI auto bin files found in f-body's. Everything is the same except for the fuel cut off speeds and ESC error min coolant threshold.
The ANTT has a 115 cut off, 110 resume while AXKT is 108 cut off, 106 resume. The ESC is different and this is my question. ANTT is 53 dec (0-254) while AXKT is 12. All I know is that 80 = 160^f
I could look through the source code but I don't want to waste my time if somebody has any info about this constant.
Car: check
Engine: check
Transmission: check
Re: 305 TBI auto bin compare, interesting
LD48A: FCB 53 ; 87c, coolant thres low
LD48B: FCB 12 ; 150c, coolant thres high
For conversion see:
;* Table 1 --- Coolant Temperature, 1k pu
RBob.
ambainb
Apr 25, 2016 09:21 PM
