distributorless ignition?
Old Nov 7, 2002 | 02:10 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Has anyone ever converted the Thirdgen HEI or Forthgen OPTI-SPARK to a distributorless ignition? I have always wanted to use a Coil pack instead of the distributor. The reason I mention the Forthgen computer is because the only thing stopping me from putting a Forthgen computer in my car is the OPTI-SPARK distributor the LT1’s have.
Old Nov 7, 2002 | 07:29 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Yes, the 4gen LT1 cars can use CNP from the LS1. So basically you have to convert your distributor to accept an opti and use the LT1 ecm (8051) with a convertion box from Bailey engineering and get a set of LS coils. Problem is money. Getting an opti and 8051 pcm and the Bailey box and LS coils will run you about $1K if you don't get some serious hook-ups. Then you have to make the opti fit the dist which is up to a machine shop. BTW, the opti sensor itself is very small. The large size of the housing is because of the need to run a cap and rotor but that won't be necessary with the CNP.
Old Nov 8, 2002 | 04:05 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Instead of using the opti spark to trigger the ECM why not just us a crank trigger?
Kat
Old Nov 8, 2002 | 06:00 PM
Bobalos's Avatar
I know of a guy that is running a EDist with his SD setup (7730) & CNP coils (this is an old Oldsmobile). The trick was putting a "cam Sensor" in his Dissy, to trigger the EDist.
BW
Old Nov 8, 2002 | 06:39 PM
hectorsn's Avatar
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
Yep, forgot to mention you could use the eDIST for this. The Cadi 4.9L PFI engine that isn't a Northstar has a dist. with a cam sync signal and MSD sells one too. I like the LT1 idea for the use of the ecm with its SFI and ALDL tuning capability. However, if using an 8051 LT1 PCM you must use the opti as the ecm won't recognize any other signal than an opti. Unless of course you're really good with code and maybe some hardware changes and make it see whatever cam/crank sync you want.
Old Nov 10, 2002 | 02:22 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
I have always wanted to use the 95 LT1 computer because you can flash it, so I could pull over flash the chip start it up and tune it some more. Would there be a way to add a crank sensor and covert the output to make it so the ECM wouldn’t know the opti is not there. You would have to rig up a coil pack some how too. Also what is eDIST?
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
