Question about AutoXray KNOCK COUNT.
Old Nov 24, 2002 | 05:01 PM
dahlman's Avatar
Anybody knows if the AutoXray scanner counts only bad knocks or is it supposed to increase all the time?
It is increasing on my veichle when i stand still and roars the engine.
Normal operation?
Old Nov 25, 2002 | 01:21 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Knock Sensor Range: 0 to 255
Knock activity noted by the ECM. When the value reaches the maximum
of 255, it jumps back to 0 and continues counting upward. It provides an
indication of knock and that a resultant timing adjustment has been made.
If the number is increasing during Monitor Mode, then knock is occurring.
On some engines the value will reset with each correction made.
Old Nov 25, 2002 | 03:33 PM
dahlman's Avatar
Thanks for the help man!
(Ser att du är svensk! Du har väl tittat in på forumet http://performerz.kod.nu)
Old Nov 27, 2002 | 04:29 AM
dahlman's Avatar
Mabey you guys could help me sort out another operational value in AutoXray's scanner:
What is the "Block Learn Cell" parameter?
Old Nov 27, 2002 | 05:56 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Read!
http://www.gnttype.org/techarea/faq/BLMINT.html
If you have any quest. feel free to mail me.......
Old Nov 27, 2002 | 06:00 AM
dahlman's Avatar
I know what the BLM and INT are.
But what i don't understand is what the
"Block learn cell" parameter on my scanner means.
(The scanner also have the BLM and INT parameters)
Old Nov 27, 2002 | 06:33 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
It shows in what cell "you" are in .....
There are four RPM bands: 0-700, 700-1200, 1200-2000, 2000 & up.
There are four MAF bands: 0-12, 12-22, 22-34, 34 & up.
Cell 0 is 0-700 rpm, 0-12 g/sec, and so forth...
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
