What to do first Inj Constatant or VE Table
Old Nov 27, 2002 | 04:51 PM
IroczInOz's Avatar
My car is running very much on the lean side with the BLMs around the 150+ mark all the time basically.
Wanted to ask what the recommendations are:
1. Currently the injector constant is set correctly at 19lbs as I have not modified the stock chip at all. Should I lower the injector constant to richen it up?
2. Should I recalculate the VE values first?
What is the better option out of these 2??
Thanks,
Michael
Old Nov 27, 2002 | 08:27 PM
kevinc's Avatar
Car: 1982 Z28
I generally adjust the injector constant until the BLMs are straddling 128...some higher than 128, some lower than 128. Then I start tuning VE.
If you're seeing need to set VE values >99 to get BLMs where you want, time to go back to the injector constant.
Old Nov 28, 2002 | 06:12 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: What to do first Inj Constatant or VE Table
You set the injector constant to what you're actually running, THEN optimise the chip's parameters to satisfy the engine.
There is more in the chip then BLs and twisting things to just get that right will lead to glitchs later.
Old Nov 28, 2002 | 11:15 PM
86 IROCZ28's Avatar
The car has a LB9 and those engines came out with 19lbs injectors so that's why I said I am running a stock configuration on the chip.
KCG
Jun 24, 2020 04:33 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
