New Part Number for 749 Puter
Old Nov 30, 2002 | 05:30 PM
SABLT194's Avatar
I've been looking for a Turbo 1227749 ECM and I ran across a new number. Does anybody know if 16198263 is really a 749 that will take $58 code. I can still buy the 16198263 through GM parts direct.
Also, I need a GM part numer for a 2 Bar MAP sensor for the 749.
The boosted 455 olds is about to come to life!!!!!!
Thanks,
Steve
Old Nov 30, 2002 | 06:18 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
That is correct.
The MAP # is 16254539
Too make it real sani...the GM MAP sensor weather pack plug with wires is a 15305891
Old Nov 30, 2002 | 07:02 PM
SABLT194's Avatar
Thanks Governor!
Old Jan 13, 2003 | 09:10 AM
Balael6's Avatar
Car: 1988 Formula
Engine: Twin Turbo .60/.63 305
Transmission: T-5 5 speed
So is that the correct number from gmpartsdirect for the 749 ecm? just curious if anyone found out.
PJ
Old Jan 13, 2003 | 06:34 PM
SABLT194's Avatar
The 16198263 part number is correct. I purchased one from GMpartsdirect and it worked just fine running the $58 code. That being said, I believe that if your planning to run high impedance injectors, the 730 ECM will run the $58 code also. As a matter of fact I was running the $58 code in a 730 for a short time when I was trying to sort out some other problems.
Hope this helps
Steve
Old Jan 13, 2003 | 10:55 PM
Balael6's Avatar
Car: 1988 Formula
So running the $58 code in the 730 is possible? Is it still possible to read the two bar map? Cause if that's true, then I would definately like to buy the much cheaper and easy to find 730 ecm, instead of the 749.
Balael
Old Jan 13, 2003 | 11:06 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Balael
Yes its possible.
The 2 bar capability is in the code, not the ECM. However like Sablt194 said, the 730 only has one injector driver, therefore only saturated injectors will work. BW
Old Jan 14, 2003 | 10:04 AM
Balael6's Avatar
Car: 1988 Formula
Gotcha. Thank ya for the info. So the 749 can use either type of injector? Sorry, im starting to get the hand of programming, but still not quite sure on all the difference's between the codes and ecms. I got a good deal on 42lb/hr greentop ford injectors, is there anywhere i can look to see what type of injectors these are? thanks guys, you are all a lot of help.
PJ
Old Jan 14, 2003 | 11:57 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
PJ
The 749 has 2 injector drivers, however they are limited to 4 Peak and Hold (low z) injectors with the OEM fets. However, they can be upgraded and 8 P/H (low z) injectors can be used. The injector wiring must be changed to Turbo Sunbird locations. Also one of the ECM power fuses will need uped to 15 amp.
You can take a multimeter and measure the resistance of the injectors across the two terminals. Saturated injectors (high z)should read ~15 ohms. Peak and Hold (low z) will be less than 5 ohms. Make sure your meter is zeroed when shorted. I had a meter go bad on ohms only, min read was 11 ohms plus whatever I was measuring... BW
Old Jan 14, 2003 | 12:36 PM
funstick's Avatar
saturn5 do you know what p# fet they are using to replace the stock fets with ??
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
