SD conversion gone wrong!
Old Dec 22, 2002 | 05:45 PM
JAY87GTA's Avatar
Here's my problem. I converted over using a 727 ECM. I know, I had to be different, but it's what I had. Anyhow, for some reason now I've got ground on the ground side of the injectors all the time. It never pulses. I've got the ground hooked up in the D9 and D3 terminal at the ECM and a ground source in D4 and D10. Did I mess up or is it possible the injector drivers are bad in my ECM? Please help! Thanks
Old Dec 24, 2002 | 11:01 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: SD conversion gone wrong!
As I recall the 727 just uses one injector drive. An ohm meter will tell the tale.
Go from + to a 1K reistor to the ijector pin at the ecm. If the light is always on, then the ecm is commanding the injector to fire.
Usually an injector driver goes open, or erratic.
I don't recall ever seeing a shorted driver, but it could happen.
Old Dec 24, 2002 | 08:48 PM
JAY87GTA's Avatar
Only uses one driver? Maybe that explains it. The dang schematics show 2 drivers. I'll try to wire it up one at a time then, see what happens. Thanks and merry christmas!
Old Dec 29, 2002 | 10:33 PM
HighHopes85's Avatar
According to the Helms Diagrams...
D9-Injector driver-Injectors 1,3,5,7-INJ 1 fuse
D3-Injector driver-Injectors 2,4,6,8-INJ 2 fuse
D4-Injector Ground
D10-Injector ground
D4/D10 have a common common once outside of the ECM.
Old Dec 30, 2002 | 07:42 PM
JAY87GTA's Avatar
Ok, here's what I found. With everything plugged in I've got power and ground to the injectors. Unplug connector D from the ECM and my ground goes away. With D plugged in but pin D3 out, I have no ground. So I'm pretty sure that the injector driver is bad or I'm getting an incidental ground somewhere inside the ECM. Sound like the right ASSumption to you guys? Thanks for the help!
Old Dec 31, 2002 | 03:54 AM
Did you check for a blown fuse?
Old Jan 1, 2003 | 01:08 AM
JAY87GTA's Avatar
Blown fuse to what? I've got a constant 12 volts to one side, and a constant ground to the other. From my understanding the ground should not be there constantlt. It should pulse when the computer commands the driver, which would fire the injectors. This is my understanding, am I wrong?
Old Jan 1, 2003 | 06:36 AM
Sorry man...I had one helluva good idea planned out for you. Went to try it out on my car and realized that either my setup is messed up from the repinning or I'm just too tired to be messing with electricity right now.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
