larger tb do i need to make prom changes?
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
im ordering a larger tb 52mm and will be making some data runs next spring as the car is parked for the winter now.i'm also planning the 749 swap. but right now i've got my prom pretty close and dont want to add any more variables into the swap.so what do you think will a larger tb throw off my existing prom to any extent?should i do the 749 swap and dial it in then add the tb or dosent it matter ?
thanks
pete
thanks
pete
Sanjay
Aug 12, 2015 03:41 PM
