anyone use this combo with a MAP car. And did you have tuning problemes, or whas it ok?
regards
regards
I answered this in the other forum you posted it to, but the quickie answer is I'm using HSR with HOT cam and MAP setup, no complications tuning it. Just built the VE table based on BLMs, then did the PE table on a dyno with wideband O2 sensor.
