at a cross road with dfi or 7730 leaning to 7730
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
ok i know this has been asked but here it goes im running a 165 ecm "maf" on my 383 LT! intake 10.5-1 195cc heads 165 roller rockers compucam 2032 214-220 duration ive run a best of 12.4@110 with an ed wright chip now ive already bought a gen 6 dfi but im having prob with it reading the ecm so im frustrated so i started reading your diy proms and im getting interested in this i like the idea of no additional cost for knock sensor orr tcc lockup like ill have with the dfi ive even considered gen 7 but for $2000 i can buy my hooker jet hot super comps and more so what im considering is 7730 and painless harness my car is a 92 rs i put tpi maf system in it about 2 yrs ago if i had known then what i know now i would of went map then i could jus put my maf harness and computer back in but if im going to go through all this rewiring hassel id like to see a gain im pretty fimilar with fuel injection but your guys computer language with burning scares me im running #24 injectors now is thier a limit om size of injectors with 7730? i wanna upgrade to 30#'s any and all imput is greatly apoprecated thirdgen.org has helped me so much over the years thank you
also can i run a less ceterline on my cam like a 110 so i can get some lope or will it not run right with the 7730
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
A 7730 has one injector driver designed for saturated (high impedence) type injectors. This style is available to +50 lbs. I am running 30's atm on my 7749,(a 7730's fraternal twin). BW
Car: check
Engine: check
Transmission: check
Re: at a cross road with dfi or 7730 leaning to 7730
eh?
RBob.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
First off, if you wanna goto 7730 you can do it now with your existing harness. You'll need
1) 7730 ecm and memcal
2) Knock sensor for 7730, or a pack of resistors
3) Map sensor, with plug (from carb car, tbi car, etc)
And like an hour and a half of uninterrupted time. The dox are in the tech section.
7730 Solved all my maf problems, and I've only got about an hour into the chip. This is just basic setup stuff, no optimized VE changes, etc. And I spent over a year with the $68 (165) setup.
-- Joe
-- Joe
