350 TBI help!
Old Jan 28, 2003 | 12:41 PM
91RedFirebird's Avatar
Car: 91 firebird
Transmission: t-56
350 TBI help!
I'm just finishing up a 350 LT4Hotcam motor and 6-speed for a 91 TBI firebird and I'm clueless.......
What programs, programer or what ever is recomended of the 1228746? And NJ Speeder said to ask about lockers program and help or just a point in the right diretion would be welcome thank!!!
Old Jan 28, 2003 | 08:44 PM
JPrevost's Avatar
Car: 91 Red Sled
Lockers is a way to datalog @ 15fps vs winaldl/diacom @0.8fps. It's a great DIYer project. I'm sure RBob will reply. With your setup I sure hope you're running 90# big block injectors and have the rest of the fuel system up to par. What heads are on the motor? Vortecs are pushing at least 400hp, more if you've got a single plane (which I hope if you're keeping TBI).
The 6 speed is nothing, the trick is to just start with the ANLU eprom and make the changes for the stick. If you've got the burning equipment then I can show you the differences and what needs to be changed.
Old Jan 29, 2003 | 06:59 AM
Car: 91 firebird
Transmission: t-56
I hate to say this but its a big cam in a to small motor the heads are 14102193. do to poor high lift flow I put 1.52 rockers on them and the intake is a ported Edelbrock TBI with a 454 TBI. I would use a single plane but I have to pass inspection, there is no sniffer test but there is a under hood check. I was not sure what injetors to run. I have not got any equipment for burning yet I want to make sure I don't dump my money in to items I will never use.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
