probably simple question...
Old Feb 18, 2003 | 08:47 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i programmed a chip (actually just tried to copy the stock one) and put it in the adapter with the stock memcal plugged in to it. the question is....why does the fan come on when you turn the key to 'on' and, it idles at about 1500 rpms.....what am i doing wrong? are you supposed to leave the stock chip in the memcal when you plug it in to the adapter?
Old Feb 18, 2003 | 10:09 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Sounds like your computer isn't reading the chip properly and is running off of the limp home chips. Is your check engine light on when it is running? Check to see it burned properly and the orientation of the chip is correct.
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
