zzz prom
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
zzz prom
Any one have a copy of the bin for the zzz engine? Also will that work with an 87 LG$ ecm? From what I have read that is what it is for...
Car: An Ol Buick
Engine: Vsick
Re: zzz prom
At one time they were dirt cheap from GM. There are several versions, depending on the ecm used. The ecm using the K/S as mentioned in the kit instructions is the only way to fly.
On the CCC the chip's easy, the trick is the mechanical bits on the carb. Lots of room for improvement, other then just changing hanger, and secondary rods.
