Anyone have this problem?
Old Feb 19, 2003 | 05:24 PM
JAY87GTA's Avatar
I'm getting inconsistent BLM's at idle. For example, one time I'll fire the car up and I'll get an almost perfect 128/128. The next time I'll get 120/126, and then the third time I'll get a 140/138 or something like that. This is on the same day, very nearly the same temps outside. Car at the same temps. I'm wondering if there is a way to adjust this out? I'm using Tunercat, is there something in a different tuner to do this?
Old Feb 19, 2003 | 09:05 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Have you been editing the MAF table or trying to get by with juggling other entries?.
Lieing about the injector constant can lead to things like that.
Some of the large engines with stock sized injectors will take large swings in BLs to make just a small change in fuel relative to the larger engine size.
Old Feb 19, 2003 | 09:25 PM
JAY87GTA's Avatar
Ok, my bad here. I thought my sig was updated better than that. I'm running a '730 ECM with 30lbs Ford injectors. I've got the FP set at 50 PSI and the IC set at 30. Seems to idle good, and it doesn't seem to change up when at slightly higher RPM's, just at idle. I was using Trax's method of percentage changes to correct the BLM's, and for the most part it seemed dead on. Other than the idle. It kinda drove me batty, because I'd take a reading, change it, and then it would read the opposite. So for now I tried to split the difference. Is there any known problems with the Bosch O2 sensors?
Old Feb 20, 2003 | 05:16 PM
funstick's Avatar
get a heated 02 sensor if you dont already have one. sounds like its loosing heat.
Old Feb 20, 2003 | 07:11 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
50?
If your running 50 PSI then the IC set at 30 when running 30s will be wrong. You need to recompute the IC.
Also boosting F/P pressure can not be as linear as your might expect. Especially at shorter PWs.
The Bosch O2 sensors (NB), don't even make good sinkers for fishing. I got 3 junk ones in a row. Use the AC or Delcos. Heated is always a good thing.
Old Feb 20, 2003 | 08:09 PM
JAY87GTA's Avatar
Hmm, I was afraid you'd say that about the Bosch. Oh well, guess I'll try a Delco and see what that gets me. I may have to live with this for awhile though if it's because of my IC, any higher and it starts maxing out tables, so I guess I need more injector.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
