diy-wide band 02
Old Mar 5, 2003 | 09:31 PM
AustinT's Avatar
diy-wide band 02
I have a couple of problems with my wide band o2 that maybe someone could solve. This is my third board I have put together I have not had a board work yet.
Yesterday I was doing some test and the board seemed to be working fine other than it took 3 min to warm up. I added resistors and the warmup time was a little better but still not under a minute. The other concern is this. Yesterday without the resisors the sensor would read 4.0 volts in free air. when I add resistors the voltage would increase to 4.08. Is it still acurate? Today I have a huge problem. Now the output reads 5 volts after the sensor warms up. Any help would be appreciated I would hate to have my third board be a failure.
Old Mar 6, 2003 | 12:47 AM
AustinT's Avatar
I did the troubleshoot tests found at diy-efi on the board. everything is ok according to the test. all of the voltages are correct. there places on the board that read 4 volts example one of the pins at r12 reads 4 volts. The output voltage reads 5.70 volts
Old Mar 6, 2003 | 06:23 PM
AustinT's Avatar
well somthing happend because the board does not switch to 4 volts after it warms up. It will heat up at 2.46 volts and reamain at this voltage after the led comes on. I ran through the trouble shooting test again and evething checks out OK.
Any body have any ideas?
Old Mar 7, 2003 | 08:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Check that your test power supply is at least 14 volts and capable of 2 amps. It sounds as though it may not be.
RBob.
Old Mar 7, 2003 | 01:20 PM
AustinT's Avatar
Thanks RBob for your time . Ill give it a try and see what goes
Terrell351
Jun 13, 2021 01:13 PM
Elephantismo
Feb 13, 2019 12:51 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
no green
Jan 9, 2016 09:22 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
