using 32bit on 16bit car.....pp2 setup?
Old Mar 11, 2003 | 05:23 PM
joe88gta's Avatar
I am new to this , so please be kind. I am looking for the options menu to use the last 16 on the the chip. I just got the pp2 and I am using win Xp . Does it setup it up by itself? Also I purchased Tunercat with ecm_32b . Now when I programmed a chip , I guess sucessfully , I cant read it. Tunercat says I need ecm_32. I am sure this is because of the 32bit? What can I do? Do I need both programs? I would hate to waste $20. I have done some message board browsing and kind seem to find these answers. Thanks to all.
Old Mar 11, 2003 | 06:18 PM
JAY87GTA's Avatar
You need to start programming at 4000, just set the start address to 4000 on the bottom right of the PP2 screen. I did the same thing my first time.
Old Mar 11, 2003 | 09:24 PM
87_TA's Avatar
If using a flash prom to burn - set start of devive to 04000 as mentioned above..
But while trying to read the same prom you must select 27c128 as your prom to read,even though you are useing a at29c256
or else tuner will not recognize.
Old Mar 12, 2003 | 03:59 PM
joe88gta's Avatar
so then I will need the other program from tunercat?
Old Mar 12, 2003 | 09:17 PM
87_TA's Avatar
No you already have tunercat ... You are just fine.
To read a chip you burned,you must read it as a 16 bit at27c128
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
