Car runs horrid after 730 swap...Help!
Old Mar 24, 2003 | 10:33 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I just completed my 165-730 swap and my car runs very bad. The engine shakes violently, it won't tach up, even in neutral. No codes either. Anything come to mind with these symptoms? I will get a scan for you guys in the evening. Thanks for any input.
Old Mar 24, 2003 | 02:59 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Any codes? What mem-cal are you using? Check all the pins also.
Old Mar 24, 2003 | 03:23 PM
No codes. I am using a memcal from a 90 vette. I have triple checked all the repinning. Here is a scan, all the fields that are in a MAF system look fine, I haven't worked with a MAP system to know what normal values for it is. http://www.fbody.com/members/Formula355/runbad.csv
Old Mar 24, 2003 | 03:57 PM
HighHopes85's Avatar
Do you have a vacuum gauge?
I would aim for IAC counts under 25 with car in park, warmed up, no throttle applied. I have had some weird instances where an obnoxious IAC caused by other problems led to high counts and my vacuum at idle dropped about 5 to 6in-hg lower than it should have been. Makes for some rough running.
EDIT-Maybe not. I took a look here...
https://www.thirdgen.org/techbb2/sho...ht=MAP+voltage
and it appears that your vacuum reading would be considered normal. I am more used to seing kPa dislayed instead of voltage. Pardon me.
Old Mar 24, 2003 | 04:22 PM
My problem isn't just at idle. Idle vacuum is at 9" hg, which seems really damn low. I never though to check it with my MAF system.
Old Mar 24, 2003 | 07:24 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
[QUOTE]Originally posted by PLANT PROTECTION
A memcal for a 90 Vette is for a 727 not a 730. There are differences between the SD Vettes and SD F-bodies and I can't predict if the SD Vette Memcal will work. Why don't you doit right and just get a F-body memcal?
Of course you have reset the IAC?
Old Mar 24, 2003 | 07:53 PM
I found the problem. The passanger side injector fuse was blown. I was able to touch the passanger side header tubes after a short trip. Runs like a raped ape now. As for the memcal, it needed to be special ordered from gmpartsdirect so I just bought the vette memcal from a local guy, sometimes I hate having a high maintenance/mods daily driver. Thanks for all the input in both of my swap related posts, finally running with the 730 crowd.
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
