7747 choke functions...
Old Mar 29, 2003 | 07:00 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I have everything tuned in so it's driveable for the most part. The only issue I have left is cold start.
I've been thru a bunch of hacks multiple times, and I see that there are ALOT of things that all work together to form the final choke function.
I was hoping someone could shed some light on this as I'm having trouble putting it all together.
I got all this stuff from the ARJU hack:
Code:
        ; CHOKE FUNCTIONS
LD2D2   FCB  8      ; 1.8 SEC'S, COLD AFR (CHOKE) TIME OUT
LD2D3   FCB  10     ; 2 SEC'S, COOL TIME OUT (CHOKE)
LD2D4   FCB  10     ; 2 SEC'S, HOT TIME OUT DECAY
LD2D5   FCB  64     ; 80c THRESH FOR TIME OUT DECAY
        ; TIME OUT AFR vs COOLANT
        ORG $0427	;  AFR       DEG c COOL
LD427   FCB  59     ;  5.9			COLD
LD428   FCB  45     ;  4.5			 -7.0
LD429   FCB  37     ;  3.7			  6.5
LD42A   FCB  32     ;  3.2			 16.0
LD42B   FCB  27     ;  2.7			 24.0
LD42C   FCB  27     ;  2.7			 31.0
LD42D   FCB  27     ;  2.7			 37.3
LD42E   FCB  27     ;  2.7			 43.7
LD42F   FCB  27     ;  2.7			 49.7
LD430   FCB  27     ;  2.7			 56.5
LD431   FCB  27     ;  2.7			 63.5
LD432   FCB  27     ;  2.7			 71.5
LD433   FCB  22     ;  2.2			 80.5
LD434   FCB  22     ;  2.2			 92.0
LD435   FCB  22     ;  2.2			108.5
LD436   FCB  22     ;  2.2			138.5
LD437   FCB  22     ;  2.2			HOT
        ; TIME OUT DECAY MULT vs COOL
        ; TABLE = FACTOR * 256
        ORG $0438   ; MULT    Deg c COOL
LD438   FCB  243    ;  0.949       COLD
LD439   FCB  248    ;  0.969       -7.0
LD43A   FCB  251    ;  0.980        6.5
LD43B   FCB  251    ;  0.980       16.0
LD43C   FCB  243    ;  0.949       24.0
LD43D   FCB  243    ;  0.949       31.0
LD43E   FCB  251    ;  0.980       37.3
LD43F   FCB  251    ;  0.980       43.7
LD440   FCB  251    ;  0.980       49.7
LD441   FCB  251    ;  0.980       56.5
LD442   FCB  251    ;  0.980       63.5
LD443   FCB  251    ;  0.980       71.5
LD444   FCB  251    ;  0.980       80.5
LD445   FCB  243    ;  0.949       92.0
LD446   FCB  243    ;  0.949      108.5
LD447   FCB  243    ;  0.949      138.5
LD448   FCB  243    ;  0.949      HOT
LD2FE   FCB  27     ; 2.7:1 AFR TIME OUT FOR COLD PK to DRIVE
LD2FF   FCB  50     ; 10 sec DELAY FOR COLD AFR PK to DRV CHANGE
Old Mar 29, 2003 | 07:26 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Keep your current chip intact, so you have a know way of starting the engine.
For doing this you might install one range hotter of plug, at least till you get the hang of what you're doing.
First Make Absolutely sure your Min Idle speed and IAC count when warm is 100% the way you want them.
I haven't looked at the 747 lately so there may be some differences from what I mention to what you see.
Then make sure you Max IAC is higher then any other entries.
The Park posistions might need adjusting, try higher first. Too small and the motor goes way rich at first start. Just change the step counts by 2. Big changes can get you lost quickly.
Look at the TPS crank enleanment and note how your clear flood mode works.
Then trying LEANING the crank fuel stuff SLIGHTLY and see how it starts, it should be obvious when you go in the wrong direction.
It's easy to go too rich during crank and foul the plugs. Gotta go slow take notes, and be sure it's really as cold as possible just having heat in the intake manifold can mess up the procedure.
really shouldn't have to worry about the spark and fuel decay rates.
The park posistions and IAC posistions do ALOT.
Old Mar 30, 2003 | 08:09 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Yep, I didn't change much of the choke functions, but I set the IAC park to 100 and max retract to 140. Now it starts smooth with almost no knock AND it idles real high like I want it to.
Before I had the max retract AND park set to 100. I guess that was just too low. Like you said, max IAC needs to be higher than the other entries.
Old Mar 31, 2003 | 02:16 AM
JPrevost's Avatar
Car: 91 Red Sled
Bingo! IAC is evil, just remember that . I had the EXACT problem yesterday when the weather got cold again and the car was running really rich fouling the plugs and not restarting right away. Even got as bad as having to require my TPS position to be 50% for a 20:1 "clear flood afr". Had to use that a couple times. Anyways, turns out I wasn't running enough timing and too much fuel but also the IAC park position was at 50. I can't remember why I moved it there but I did, anyways, try setting it to 0 and starting. It most likely won't. Put the IAC back to 160 and she fires right up. I still had to lean it out a little but that was also because of the vac.rafpr. Let's just say that I have a VERY strong feeling that the Holley regulator isn't good for less than 14psi of fuel pressure with the walbro 255lph fuel pump. If it is, I can't figure it out and I thought all I had to do was back off the spring .
Oh yeah, and those AFR's are added to another table. Should be a couple or a few, can't remember but in the 8746 they're only a page apart. I believe the other adder table has to do with either baro or just engine map. If you've got the time check it out. It's pretty cool charting out the tables in excel to make sence of it all.
Old Mar 31, 2003 | 01:20 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
IAC as used in the Trottle Follower can be a handful to work with, but it not hardly evil.
It's Baro and only makes a tiny change. It accounts for the change in exhuast back pressure due to atmospheric conditions.
If you park in a heated garage, and then pull out into freezing conditions you can notice a change after it does a reset, but it's not a big deal on any one given day, when driving in normal conditions.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
