Pulling enough vacum for motor?
Old Mar 31, 2003 | 02:06 AM
mastrdrver's Avatar
I was wondering if you guys had any idea if the 236/242 112 XE roller cam would pull enough vacum on a 350 for SD to work without a 1500rpm idle? Also I was told that you could run the the MAF ECU and for WOT just keep adding to the PE tables bcuz of the MAF limit, was wondering if this is true?
Here is the motor if anyone needs to know.
zz350 shortblock
ported Pro Action 200cc heads
HSR intake with 58mm TB
1.6 roller rockers
1 3/4 hooker headers with mufflex catback
236/242 112 XE HR cam
it will have either a 5 or 6sp manual with 12 bolt with 3.73s
Jeremy
Old Mar 31, 2003 | 07:24 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I can say Yes to #1 in terms of Speed Density. I've never worked with a car running a cam that big on a 350 with MAF.
True to #2.
Definitely be worried about your brakes with the vacuum that cam is going to produce.
Tim
Old Mar 31, 2003 | 11:48 PM
mastrdrver's Avatar
What is your idle set at with that cam on your webpage?
Old Apr 1, 2003 | 11:12 AM
TRAXION's Avatar
850 at normal coolant temps.
Tim
Steve78LT
Feb 24, 2016 12:15 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
