getting ready to burn my own PROMs
Old Mar 22, 2003 | 11:57 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
I finally received my new heads and now I've pretty much got all the major parts to finally get the car back together now. It's just a matter of setting the time aside to install the new cam and everything else to get the car going. I'm thinking it's probably a good time to begin to learn about burning my PROMs now as well. Tim's (Traxion) article on PROM burning is awesome....I'm just curious if there is one main PROM burner that people recommend over others? Tim's got 3 brands listed so I'm wondering the limitations (pros/cons) of one vs. the other? Also is there a particular programming software package that people recommend as well?
Thanks in advance for the suggestions...I'll be spending alot of time in this forum from now on and learning from the masters....I'm looking forward to it.
- Joel
PS - Also since I've got a 1992 Z I can use the EEPROM chips and won't need a UV light prom eraser....any suggestions on how many EEPROMS I should buy?
Old Mar 23, 2003 | 12:14 AM
Morley's Avatar
Most here use the Xtronics Pocket programmer 2 for burning ($150). I use the SPEP II from Futurlec ($80) found here http://www.futurlec.com/EPROMProg.shtml even though it dosen't list them, it will program the 29 series chips.
Ater those 2 things get more complicated (jumper settings on boards) and more expensive.
For editing bin files I'd say its almost a 50/50 split between Winbin (free) and Tunercat ($100 for prog and $20 per ecu definition file).
For the number of chips, you really shouldn't need more than 2
Old Mar 23, 2003 | 08:15 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: getting ready to burn my own PROMs
I use two pocket programmers, one on the laptop and one in the house. Pocket Programmer II will do all the chips I've run into, but it takes more then a 486. I've run Pocket Programmers for at least 5 years and only killed one.
I get chips 4-5 at a time, cause, every once in a while I brain fade and kill em, thur some dumb act.
ALWAYS remember to keep one *untouched* so that in case of an EMP you can drive home <g>.
Old Mar 30, 2003 | 05:03 PM
Engine: 6.3L - 383
Thanks for the suggestions...I just placed my order for a PP2 and the adapter and 2 chips from Craig Moates.
I've been reading alot of the info on the Dyi site....I hope I don't get too overwhelmed when it come time to burn.
- Joel
PS - Are there any good (affordable) software packages out there to for a laptop to plug into the diag port to monitor the car to aid in burning? I'd love to get a Scantool...but can't shell out the 3K for one.
Old Mar 30, 2003 | 08:12 PM
Morley's Avatar
How about a free prog? http://moates.net/gmecm/index.html Works great on older cheap laptops too.
Old Mar 30, 2003 | 08:38 PM
Engine: 6.3L - 383
WOW that's excellent! Thank you for the link!
- Joel
Old Mar 30, 2003 | 11:09 PM
Morley's Avatar
Also look on that same site for the schematics for building the cable to hook the laptop to the car's ALDL. The 2 transistor cable is all you should need (works fine for me) and costs about $8 in parts from radioshack.
Old Mar 31, 2003 | 06:01 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Dont use winbin there is a much better FREE program!
Download it here https://www.thirdgen.org/techbb2/sho...hreadid=164388
If you like burning PROMs you can spend 70+20$ on tunercat later......
Old Apr 1, 2003 | 02:15 PM
Ragtop89's Avatar
I'd love to see a manual or instructions on how to use the Moates software.
Doesn't seem to be a lot of documentation out there on usage.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
