what bin should i start with w/ my mods
Old May 9, 2003 | 01:52 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
my mods are listed below, its a rebuilt lo5, im running the stock caprice chip right now ANLU. does anyone know of a better chip i should start with. i dont want to learn to tune on this chip when i could be starting with a better chip.
Old May 9, 2003 | 03:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: what bin should i start with w/ my mods
Six of one and a half-dozen of the other. The problem is that there are no 350 manual trans bins for the '8746. Using an auto BIN with a stick (or vice-versa) and the IAC cal isn't right. You need to make a bunch of SA & VE changes as it is. . .
Once you try out ANLU see how the IAC stuff is. If it isn't to your liking it may be best to either got to a stick 305 bin or do a wholesale copy of the IAC parameters from a stick bin to yours.
At a minimum you should flip the option bit for tcc/shift light to shift light.
RBob.
Old May 9, 2003 | 03:44 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
I did a build up very similar to yours, but started out with the vortec heads.
My car is a 91 RS 5 speed.
Since this was my first shot at chip programming I took a very straight-forward (IMO) approach.
I wound up using all settings from my stock chip (AXKW) except that I pulled the VE table(s) and spark table from the ANLU bin.
I felt like the spark and fuel tables in the ANLU were a little closer to what I needed. It took a little tuning on each of those tables but it is working very well now.
Eventually, I could have gotten to the same point with the stock fuel and spark tables, but it would have taken more time.
Best of Luck-
S-D
ZZ3Astro
Aug 13, 2019 12:57 AM
Quzyle
Oct 15, 2015 03:35 PM
92camaro350cci
Oct 14, 2015 09:29 AM
Wade787b
Sep 29, 2015 01:15 PM
