7730 ecu
Old May 13, 2003 | 02:00 PM
papaford's Avatar
7730 ecu
how to fix this:
Invalid Item Data/Syntax in item. Check for missing comma or }.
Item number 30.
I'm trying to use this in gmecm edit and this pops up evertime I try to open the program... the program will still open after about ten hits of the OK button however something must be wrong to give this error.. I have checked Item 30 by opening the ecu file with word pad and the comma's and }}'s all look to be in the same place as the other Items in the file.. Well I thought I would attach the ecu file but it is an ivaled extension and I can't seem to convert it..any thoughts? Thanks
Old May 13, 2003 | 02:46 PM
91blackgta's Avatar
I have the same problem. I am using Win XP.
Old May 13, 2003 | 03:25 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
did you open the help file and see what was said in there?
to fix this, open the ecu as plain text and count down to the 30th item. look for incorrect ECU syntax (like a missing comma, extra comma within a title or lable, missing bracket, etc).
or, send me the ECU and i'll fix it.
gixxer92
Apr 12, 2022 12:09 AM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
KO1
16
Oct 15, 2015 05:00 PM
BWilcox
Sep 20, 2015 12:19 PM
