what is diff. between pcm&ecm
Old May 14, 2003 | 02:05 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
or am i just retarded and they're the same thing
Old May 14, 2003 | 03:55 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: what is diff. between pcm&ecm
Nah, it is a good question. An ECM is an Engine Control Module. Only controls the engine along with the TCC in the torque convertor.
A PCM is a Powertrain Control Module and along with the engine controls the transmission (automatic trans). Trans control includes line pressure and shift points.
RBob.
Old May 14, 2003 | 05:41 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
where are they located?
Old May 14, 2003 | 08:04 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Any-where. From under the hood to under the dash to under the drivers seat. All depends upon the vehicle.
Of course, this being a 3rd gen site, I'd say under the dash, pass side is a good bet, w/no PCMs to be found
RBob.
Old May 15, 2003 | 08:23 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
so i've got a big silver metal cigar box looking thing. that's the ecm, correct.
an since it's an 85, there is no pcm?
Old May 15, 2003 | 04:34 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
*left pointer finger on nose, right pointer finger pointing at you*
Old May 16, 2003 | 01:22 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
No thirdgen came with a PCM
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
