Ordered equipment to burn my own eproms, I got 2 165 ecms should I keep a spare?
Old May 20, 2003 | 03:10 PM
LetsRock's Avatar
Car: 1989 Trans Am GTA
Engine: LB9 TPI with L98 cam (Manual car)
Transmission: T5 5Speed/ 9bolt Borg-Warner 3.45 gears with posi
Im through with troubleshooting my engine problems, my problems lead me to believe its the eprom so instead of ordering a new chip I decided it was a better idea to get the equipment to make my own (after reading volumes of posts on the subject).
If the problem is the eprom I should be set and Ill have a spare 165 ecm since I thought originally my ecm was toast.
Should I keep my "spare" ecm or should I sell it? You guys are the pro's here and I respect your opinions.
Thirdgens Rock!
Old May 20, 2003 | 04:47 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Ordered equipment to burn my own eproms, I got 2 165 ecms should I keep a spare?
Thirdgens Rock!
Never hurts to have a spare, they easily fit under the seat. Can also use it for a test bench setup. This is the best part of OEM ECMS, they are inexpensive.
RBob.
Old May 20, 2003 | 06:06 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Keep it.
Once you have the car running in a given manner try the spare to make sure it's good, and then stow it.
Old May 20, 2003 | 07:13 PM
383 rocket bird's Avatar
Agreed, never hurts to have a spare of anything to test against.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
fasteddi
Sep 10, 2015 09:32 AM
TheTraut88
Sep 7, 2015 05:22 PM
mrdevontay
Sep 2, 2015 08:04 PM
