WinALDL questions...
Old May 30, 2003 | 06:54 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
A few weeks ago, I built an ALDL to serial interface for WinALDL (the commonly used 2-transistor interface).
The first time I tried to hook it all up, I had to bring a desk out to my driveway and hook up my desktop PC there. When I was ready to get started, I found that I couldn't very well get the wires to stay in the ALDL connector. I was using small (20ga) wire, so I crimped on the smallest male blade connectors I could find, but they ended up being too wide for the ALDL. So I ground them down until they fit, but then they were too thin and fell out. I ended up soldering large lumps of solder to make them hold, and then they got too big. At that point, it was dark and I was frustrated, so I closed shop.
Now, I have a laptop, so I'm all geared up to try it again. Then, I noticed that my laptop doesn't have a serial interface .
So, I have two questions:
1. Is there any way that I can interface with my serial-less laptop, i.e. using the printer (parallel) or USB ports?
2. What is the best way to hook up the interface into the ALDL connector in the car?
Old May 30, 2003 | 09:55 PM
knoxbonnie's Avatar
I had the same frustrations building my own cable. After about 2 weeks of bad connections and crappy data logging, I bought one from AKM that has the proper molded end to it.
http://www.akmcables.com/
You might be able to use a USB to serial convertor.
JmeierZ28
Apr 8, 2002 12:06 PM
JmeierZ28
Mar 20, 2002 06:11 PM
lars92RS
Feb 25, 2002 10:40 AM
JoBy
Feb 9, 2002 06:08 PM
