burned another PROM, now car won't start
Old Jun 5, 2003 | 08:56 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
Burned some of my first PROM's this past weekend and i got the car running alot better. Yesterday I made another one and put it in the car after making some IAC adjustments and the thing won't start now. I put the other program on the chip that worked before and it still won't run. It turns over and sputter a little bit. Anyone know what's going on? Is there a chance that I fried the ECM somehow? BTW, I tried jumping the ALDL to read any codes, but when terminals A&B are jumped, the SES light won't flash. If the ECM were toast, it would give me a 'bad ecm' code wouldn't it?
Old Jun 5, 2003 | 09:01 PM
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
Are any fuses blown?
Old Jun 6, 2003 | 07:29 AM
Engine: LB9/383
All fuses are good. I checked the resistance of all of my injectors which are LT1 24# and they were all within the 14-14.5 range.
Old Jun 6, 2003 | 05:04 PM
Car: 85 Corvette
What bin are you using? Do you have VATS disabled? Could your SES light be burnt out? Try disconnecting the battery to clear everything.
Old Jun 6, 2003 | 08:49 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Got the notch in the chip towards the end of the Memcal?
I put mine in backwards once. The SES light wouldn't come on and the fuel pump ran all the time. Wouldn't start either
Old Jun 6, 2003 | 10:12 PM
Engine: LB9/383
It's an $6E ARAP bin with no VATS. The SES light comes on with the key. The arrow on the EPROM is facing the right way. Thanx for the help. Keep it comin!!
Old Jun 7, 2003 | 08:16 AM
Car: 85 Corvette
Did you use the 04000 offset or double stack the bin when you programmed the chip?
Old Jun 7, 2003 | 08:53 AM
Engine: LB9/383
I have absolutely no idea what that means . Like I said, I 'm still new at this so could you explain that to me please?
Old Jun 7, 2003 | 09:19 AM
Car: 85 Corvette
Could you tell me what bin editor you're using and what programmer you have and what type of chip.
Old Jun 7, 2003 | 10:47 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Do you have another chip? You said you put the old program back into the same chip, but I would try another chip. When I fried one of my chips, it did the same thing.
Old Jun 7, 2003 | 04:20 PM
Engine: LB9/383
I have two chips. What I meant was that I had put the first chip back in it. Thanx again for all the help! Keep it comin' pleeeease!
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
