Where should Resistor go?
Old Jun 11, 2003 | 05:26 PM
89transam's Avatar
Where should Resistor go? (pic)
Im having the dardest time hooking my car up to my laptop. Someone said that the resistor may have not been included in Steve Ruses's cable.
Where would I look? Or can someone tell if it is correct in the pic? (i doubt as the pic is terrible)
Any help would be :hail: . Because its baiscally come down to , either get this thing hooked up or sell the car....
Nate
Old Jun 14, 2003 | 11:09 AM
3gc's Avatar
3gc
Car: Z28
I'm having the same problem with my cable. Although mine is a lot different looking, it's from customefi.com. I don't know wether it has the 10k ohm resistor in it either but it's not reading from the computer. All i get is three lines of raw data in winaldl wen i hook it up.
Could i just place it right after the wires come out of the aldl connector?
Old Jun 14, 2003 | 08:39 PM
Bluevette85's Avatar
Car: 85 Corvette
Engine: 355 Superram
Transmission: 700R4 Transgo Shift Kit
The 10k resistor isn't in the adapter picture you posted. It is inside the connector that plugs into the adapter going to the aldl.
Old Jun 14, 2003 | 08:52 PM
3gc's Avatar
3gc
Car: Z28
The cable i have has two prongs that i plug into the aldl port. I got it to work earlier today, i used a 10k ohm resistor and put it between A and B and then pluged the prongs in. Worked well. I just want to figure out a better way to put that resistor there. It'd be cool to hard wire one in with a switch so i can put it on when i want, so i just have to plug the aldl thing in.
Old Jun 15, 2003 | 12:31 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
What's the benefit of a big fancy cable like that, when I've got the piece of cake to make 2 transistor simple cable working for me?
Elephantismo
Feb 13, 2019 12:51 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
studebaker60
Sep 7, 2015 12:36 PM
greenyone
Aug 29, 2015 11:08 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
