sensitive engine for knocks.
hello
Im just about finnish with my VE tabels.
Im around 124-130 from idle to PE mode.
I noticed that my engine is very sensitive to fast changes in the integrator. I will take a exampel:
My BLM is 126 @ 1600rpm and integrator is around 125/128.
Then when I climb to 1800rpm my BLM is still 126 but the integrator start to climb slowly to 132. And as soon as the integrator starts to climb i start to get knock counts.
I understand that I can get knocks if the BLM starts to climb abow 134, but is it normal to get knocks when the integrator start to climb? Mayby I can take out some timing in that area?
I just whant som feedback on the subject.
thanks
thanks
84z96L31vortec
Aug 20, 2017 12:16 AM
