Error Code 51 - Prom Error
Old Jul 14, 2003 | 07:49 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
Just recently I started recieving a ERROR CODE 51 (PROM ERROR).
I've tried several different BIN files and they all seem to get the error at one time or another. Wierd thing is, I don't get it all the time and haven't found a pattern in when I do.
Does anyone have any experience with this error and what might cuase it? Could it be the way I'm burning the chips? ECU I'm using? Editor I'm using? Should I find and turn the error flag off?
Using:
165 ECM
ARAP BIN
6ev101 ECU
As always, thanks for any input you can provide.
Old Jul 14, 2003 | 07:54 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Make absolutly sure you have the prom seated correctly. Im not sure if your using a zif socket or what, but I used to get errors with my pocket programmer not recognizing the prom it had everything to do with my solder connections. I would imagine if you have poor connections just a little movement would cause that error. Now I always go back with a continuity tester to make absolutly sure every connection is making contact.
Old Jul 14, 2003 | 08:08 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
I am fairly comfortable that the connections are good. I have to brand new memcal adapters that I swapped out early today to confirm. But since you bring it up, I will pull out all the pieces and check them individually.
You never know, sometimes it's the obvious things you overlook.
Thanks.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
dusterbd
Sep 29, 2015 08:40 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
