Big cam, base timing, engine rpm
Old Jul 18, 2003 | 09:20 AM
OMINOUS_87's Avatar
The engine is as follows:
Superram, 383, 224/230 .537/.544.
The combo is not crazy extreme but likes to idle at about 850-900 rpm in park. I am starting with an ARAP base bin. Right now the car is idling real well, mid 130 BLM and no knock counts. My question is about the base timing. We all know that the tan/black wire needs to be disconected and base timing should be 6-8 degrees. Ok so now, I set my base to 6, I am having no problems, but i set it at about 900 rpm, is this fine?
So basically, is there a difference between setting my base timing to 6 at 900rpm Vs. 6 at the factory 550rpm? Should i be in park or drive? Anything else i need to know?
Thanks for the help guys!
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
camaro71633
Sep 1, 2015 10:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
