Help please 89 chip/ecm in an 88 car/tpi/wiring???
Old Jul 25, 2003 | 11:14 AM
88irock's Avatar
Will an 89 ecm, chip for a 350 work in my 88 iroc? I need a 350 auto chip, and found one for an 89, with ecm, for a good buy. Will it work? Thanks for the help.
Brandon
Old Jul 26, 2003 | 09:18 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
since you have a 350 auto and 88+89 are 165 type it will work. just make sure it your buying a 165 ecm. the only thing is, i would disconnect the cold start injector. why? the 89 code has been "refined" to no longer need the assitance of the CSI. upon a cold start, it fires all 8 injectors. additional fuel is added upon a cold start. it "primes" the engine, so it will start w/o the CSI.
hopefully the ecm/memcal are functional.
best of luck
Old Jul 26, 2003 | 10:52 PM
88irock's Avatar
Thanks for the tip, I'll probably try it...
Old Jul 27, 2003 | 06:34 PM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Re: Help please 89 chip/ecm in an 88 car/tpi/wiring???
Brandon
Don't forget to disable VATS in the '89 chip or you will have a very hard time trying to figure out why your car won't start....
Old Jul 27, 2003 | 06:48 PM
Car: 1988 IROC-Z
oh **** i forgot about that. as mentioned vats must be disabled or the injectors won't fire.
Caver Dave
Apr 28, 2009 08:44 PM
Cody Ashby
Alternative Port EFI Intakes
Aug 2, 2008 04:05 PM
ZEEYAA
Jan 3, 2007 08:48 PM
jeeps2creep
Dec 17, 2005 09:32 PM
tanager11
Jun 29, 2005 01:38 PM
