Add ecu item?
Old Jul 27, 2003 | 03:25 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Add ecu item?
Hi..
I need to add some tables to my 8D.ecu file can someone tell how to do it ? using GMEDIT.
What the starting adress is and do on......
The things I like to add are
;IDLE SA RETARD vs RPM
; TBL = SA * (256/90)
; S.A. RPM
L81EB: FCB 0 ; 0.0 0 RPM DIFF
FCB 14 ; 5.0 50
FCB 14 ; 5.0 100
FCB 14 ; 5.0 150
FCB 14 ; 5.0 200
; IDLE SA ADVANCE vs RPM ERROR
; TBL = 256/90
; S.A. RPM ERROR
L81F0: FCB 14 ; 5.0 0
FCB 14 ; 5.0 50
FCB 14 ; 5.0 100
FCB 14 ; 5.0 150
FCB 14 ; 5.0 200
Thanks!/N.
Old Jul 27, 2003 | 06:23 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Add ecu item?
; S.A. RPM
FCB 14 ; 5.0 50
FCB 14 ; 5.0 100
FCB 14 ; 5.0 150
FCB 14 ; 5.0 200
; TBL = 256/90
; S.A. RPM ERROR
FCB 14 ; 5.0 50
FCB 14 ; 5.0 100
FCB 14 ; 5.0 150
FCB 14 ; 5.0 200
In the first one the actual address is 01EB.
The second one it's 01F0.
If you look at your editor then find a spark table, that used the same conversion of 256/90 and just change the entries to these new ones. Sometimes the editors use an offset so the address might be 41EB, or something strange looking, but as long as the last three places are the same, you should be there, and then when you load a .bin the numbers should all make sense.
F-body-fan
Jan 12, 2023 01:49 PM
KO1
16
Oct 15, 2015 05:00 PM
bigjay89gta
Oct 15, 2015 08:04 AM
okfoz
Oct 13, 2015 02:19 PM
gord327
Oct 3, 2015 01:25 PM
