overrun
Old Aug 1, 2003 | 08:00 AM
devilfish's Avatar
overrun
I get ehxuast bangs when I keep the car at high rpm and then release the gas pedal. My O2 readings is pretty good, so i guess to much spark or to little. How to tell?
And how do you program your overrun spark? To you have little timing at a low Kpa @ hig rpm?
thanks
Old Aug 1, 2003 | 10:24 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: overrun
DFCO.
Decleration Fuel Cut Off, cuts off the fuel on decleration.
It just might have a bang depending on what your doing. Even with port injection there is some fuel in the runners, plenum, and it may take an instant to vaporize, even with DFCO. And a exhaust leak can cause the bang also.
Old Aug 1, 2003 | 11:50 AM
devilfish's Avatar
hmm ok ..
Where do I adjust the DFCO in my 730 ?
Old Aug 1, 2003 | 02:44 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
There's a series of settings for it. Might look around for commented Hac.
Old Aug 1, 2003 | 02:46 PM
devilfish's Avatar
so what do you basicly whant? To kill the fuel when you let go of the gas? Wount that create a lean condition? Cant you controll that with the VE tabels. Just take away fuel in the low KPA areas at high rpms?
Old Aug 4, 2003 | 08:54 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
You could also try to pull some spark in the low kPa overrun areas, see if it helps any.
Old Aug 4, 2003 | 02:31 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No fuel is not lean.
Lean still supports combustion, no fuel means no combustion.
Old Aug 4, 2003 | 03:24 PM
devilfish's Avatar
true..
So what that do is to cut fuel when you let go of the gas from wot? WOunt that kill the engine?
Old Aug 5, 2003 | 09:11 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
DFCO cuts fuel only for certain instances, rpms, deceleration rates, etc. If you happen to push the clutch in, and the rpms hit a certain point, the ECM will feed fuel back in to keep the engine alive...and if you never push the clutch in, then there's no problem since momentum and the car's mass will keep it spinning.
Old Aug 8, 2003 | 08:47 AM
devilfish's Avatar
where can I find a HAC to tuenr cat for that?
pajama sam
Feb 11, 2012 10:15 PM
pajama sam
Jul 10, 2011 11:08 AM
Casey Butt
Aug 18, 2006 02:02 PM
mdricken
Jul 17, 2005 09:47 PM
Rebel 92 F-bird
Dec 7, 2004 10:04 PM
