scanner help
Old Aug 5, 2003 | 02:38 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
scanner help
I am looking for a software scanner that will work with a 3.1L SD Map system,730 ECM. Does anyone know of one that will work?
Old Aug 6, 2003 | 08:34 AM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
What year is the engine? 90, 91?
Old Aug 6, 2003 | 08:59 AM
mmcdjs's Avatar
Engine: 3.1 V6
scanner
It's a 91 Firebird.
Old Aug 7, 2003 | 12:12 PM
Denis.V's Avatar
Axle/Gears: No idea
Sorry,
I'm working in a 87-90 V6 730 ECM scanner. It's different.
Old Aug 7, 2003 | 12:41 PM
mmcdjs's Avatar
Engine: 3.1 V6
different
they are different? It' still the 730 ECM right? do you have a beta that I can test for you?
Old Aug 7, 2003 | 01:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: scanner help
Wasn't Pasky over on the V6 baord working w/Craig on this?
RBob.
Old Aug 7, 2003 | 02:52 PM
Denis.V's Avatar
Axle/Gears: No idea
This V6 thread has the info about my Diagnostic Scanning Software which I've named "AUTOLINK".
The last post includes a download site with the files (Autolink.zip).
If the datastream is not the same you will see some bad calculations, for example: Vehicle Speed: 500 Kmh with 25 RPMs and 1000 ºC temperature, etc.
https://www.thirdgen.org/techbb2/sho...hreadid=191285
I hope it works,
Denis V.
Old Aug 7, 2003 | 02:58 PM
mmcdjs's Avatar
Engine: 3.1 V6
scanner
Ok, I think that you have already sent that to me. I will have to try it out tomorrow, or later since I'm getting underway here very soon to go bomb some open ocean or something.
Old Aug 7, 2003 | 03:18 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
I hope it works,
Denis V.
I don't mean to be an *** here, but don't you think you ought to give source code credit to where credit is due?
Old Aug 7, 2003 | 04:36 PM
Denis.V's Avatar
Axle/Gears: No idea
This Scanning Software source code was based on an old C. Moates's stuff. The datastream is completely different.
Old Aug 8, 2003 | 07:52 AM
Engine: 5.7L TPI
Exactly, but the splash screen and source code don't give that impression...
Craig doesn't strike me as the type to ask you to credit his work, but in my opinion your source code and splash screen should say "AUTOLINK, written by Craig Moates, modified by Denis V. for use with V6 ALDL". Or something like that.
Oh, and thanks for making public a V6 enabled version of Craig's code. Top notch...
Old Aug 8, 2003 | 10:31 AM
Denis.V's Avatar
Axle/Gears: No idea
O.K., no problem with this.
All the comments are welcome here (please, note that this software is only a preliminary version).
And thanks again,
Denis V.
whtltng89
Sep 8, 2015 07:06 PM
Electro_X
Aug 19, 2015 07:59 AM
mizz0313
Aug 12, 2015 06:45 AM
bowtie1983ss
Dec 4, 2001 12:18 AM
Mark305TBI
Jan 28, 2001 11:20 PM
