Timing ? 730ECM and CM software...
Old Aug 11, 2003 | 01:56 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
After my 730swap I have done some scanning with CM software.
When I look at the scanresults the timing is 25 deg. in high rpm/load but when I look in TC It should be 28 deg in that area.
Whats the correct one?
/N.
Old Aug 12, 2003 | 08:39 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
If you dialed in 28 at a specific load/RPM then it should be 28 at that specific load/RPM unless other factors are coming into play. First - you need to make sure that you are looking at the exact load/RPM. Double check - tripple check.
The 2 other major things that come come into play for part throttle operation are Octane Retard and knock retard (assuming Highway Mode is not implemented). If the ECM senses a lot of knock all the time then it will implement a long term reduction in spark using the octane retard routines. Consider zeroing out all the octane retard as a check. Also double check that you aren't getting any knock .... and, as previously stated, make sure you are looking at the correct areas when comparing data to TC.
Tim
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
