timing questions
Old Aug 13, 2003 | 09:05 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
timing questions
is there anyway to fix the idle correction parameters with the spark table?
when im at idle my spark varies from 22 to 12 degrees... this also occurs when ive let off the throttle and the tps is at 0 % no matter the speed or rpm, instead of following my tables its all wacked out
is this normal?
730 ecm- 350 superram/cam/pro lightning heads
Old Aug 14, 2003 | 07:44 PM
91L98Z28's Avatar
Car: Z28
In short, yes.
The ecm idle algorithm uses the timing to help maintain a steady smooth idle rpm.
I think there have been other postings about how to disable or tune it, but not sure...
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
