possible gain
Old Aug 22, 2003 | 01:25 PM
DOOSKI's Avatar
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
possible gain
If you burn your own chip, is it possible to gain any hp on stock 350 map with full exhaust, afpr ported plenum? Or is it to hard to do it? I already have a performance resource chip which causes knock retard on higher rpms acording to scantool. They said that i would get 25hp so i´m losing hp instead.....
Old Aug 23, 2003 | 02:09 AM
Morley's Avatar
You could gain a few HP on a stock engine, and a few MPG too, if you play around with it long enough (or already know what you are doing).
Old Aug 23, 2003 | 06:42 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: possible gain
Doing chips will allow you to optimise whatever you have to the level of tuning you can achieve.
Given time, and there is some knack to this, you can get it right, but learning is an individual thing, some guys pick up tuning almost overnight, some take years to get it.
If your triggering the K/S then that typically takes out almost 2x timing as needed. ie if you see 4d on the scan tool you have 2d too much timng, or can be a lil lean.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
