1227165 to 1227730 Swap - Minimum prom changes needed?
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
What changed to the prom is absolutely needed for a 1227165 to 1227730 swap?
Assuming we are talking about an '89 350 TPI with stock 1227165 ANYJ9304 code, and that I will be using AUJP1615 code with the 1227730.
I read somewhere about the VSS signal being different, and that I need to change the knock sensor but is there anything more thats important to think about?
I have realized that the memcal that came with my 7730 probably is from a V6, can I still use it if I swap the prom for one with V8 code?
Memcal came with AZTY1407 code and I plan to use AUJP1615 code.
Is the knock circuitry on the memcal the same, and what about the netres?
