FMU or not??
Old Aug 25, 2003 | 11:54 AM
ostrich's Avatar
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
FMU or not??
I have a heavily modded 383 in my 89 Camaro. I'm getting a Vortech SQ-trim blower and wanted to know if someone out there is running without an FMU? I have a custom chip from TPIS and can get it reprogrammed. I'm running #24 injectors right now but will step up to may be #36. I know my friend with a mustang is doing this right now. Is it possible? Thanks
Old Aug 26, 2003 | 02:36 AM
drive it's Avatar
Re: FMU or not??
To run without an fmu you need to use either aftermarket, or factory ecm that uses a 2bar map. The sy ty ecm is one example of factory. However if you're like me, and stuck with a factory one bar map ecm due to smog checks......then it's an fmu....just make sure you use a wideband to safely tune.
Old Aug 26, 2003 | 06:56 AM
ostrich's Avatar
Car: 85 Iroc-Z
Thanks. I have hear of the 1 bar & 2 bar Map, what exactly is that, and what's the difference? I have an aftermarket TPIS chip, with the stock 89 ECM.
Old Aug 26, 2003 | 11:22 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
1 bar= reads from -1 bar to 0
2 bar= reads from -1 bar to +1 bar
If you want the ECM to know when youre under boost (over 0 bar) you would have to have a 2 bar sensor, but this is nothing you just change you need to modify more to make it work, specially on a MAF car.
Ways to go (search and check out the sticky)
- Change to 808 code and use a 2bar MAP and compress "all" the tables.
- Change to a GM730 ECM and do the same thing
- Change to a GM749 ECM (typhoon) This one is made for boosted application.
/N.
Do a search and read and post your questions.....
Old Aug 27, 2003 | 02:38 PM
ostrich's Avatar
Car: 85 Iroc-Z
Thanks, I'll check into it.
Old Aug 29, 2003 | 12:39 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: FMU or not??
There's another thread running right now about this.
Also, searching for info on 749 will get you volumes of good info..
bluegoose
Apr 4, 2003 08:00 AM
bEtUr4dRustang
Jan 23, 2003 12:39 AM
Jeremy_84_F41
Jul 23, 2002 11:30 AM
Blown WS6
Jul 9, 2002 11:50 PM
Justin 87 GTA
Jul 10, 2001 01:38 PM
