ECM Relearn required when switching proms?
Old Sep 7, 2003 | 01:21 PM
johnh's Avatar
Car: 2004 GTP CompG
Engine: L32 SC
I have Craig's Adapter so I can stack bins. If I change programs (bins) do I have to/should I disconnect the power so the ECM will relearn?
I would get that I don't *have* to...but is it better to let it relearn with the new data, or is it only if certain values change?
I would imagine things not related to BLM and INT changing shouldn't require a relearn..
Any experiences?
Old Sep 7, 2003 | 09:35 PM
JohnL's Avatar
I don't know whether bin-switching on Craig's adaptor dumps the RAM contents (and so the BLM's), but even if it doesn't, if you change crucial parameters like VE's and spark, the ECM will come up with different BLMs (and so obviously INTs).
Whether it matters that you erase the RAM or not depends on whether you're going to be running long enough to correct all the previously learned BLMs or not. I think it's easiest to be sure and so disconnect power to the ECM. If the change between the BINs is minor, then you're probably not going to worry about it.
My $0.02 worth.
John
Old Sep 8, 2003 | 12:04 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: ECM Relearn required when switching proms?
Any experiences?
I have the 16 bin switcher and never reset anything. If I switch from one bin to another that I have drastically different idle settings the idle learn gets a little screwy for a bit but straightens up.
On the BLM, the value is retained when it leaves a cell and the stored value is used when it enters that cell again, where it is recalculated and stored again. So, it only takes a short time for that to line itself out.
I wouldn't do any tuning based on those values unless I'd driven it a bit or just used some of the latter data in the scan.
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Dec 6, 2015 11:25 PM
mddaniel
Sep 8, 2015 05:16 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 10, 2015 08:42 AM
