Can this chip be burned???
Old Oct 6, 2003 | 09:41 PM
FASTRED335's Avatar
Can a chip be custom burned for a Holley 670cfm 2bbl DFI system to make it able to surpass its limits "(275hp max)" or are the adjustments ***** on the ecu enough of tunning control for most mild to wild engine moddificattions. If one can be burned, who can do it for me??? I have read what has been done with stock chips on this site, so Im curious what can u guys do with this one. Thanks in advance for any information, later.
Old Oct 6, 2003 | 10:16 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
With the 2" bores its just a matter of upping the fuel pressure. I think the 2" bores will support 400 horse, but that same "done up" small block with a big carb could have 30 - 50 more hp.
No facts, just my thoughts.
Old Oct 7, 2003 | 04:36 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Can this chip be burned???
You have to rewire it to run off of a GM ecm to be able to do a chip for it. The Holley system with the ***** is analog in nature, ie no programable chips are used.
And if you want to chip something, long term by the time you get it right dealing with just buying chips, you'll spend less to do your own. And to learn the language to talk to the chip guy intelligently is 1/2 the work of learning how to do them anyway.
Old Oct 9, 2003 | 08:50 PM
FASTRED335's Avatar
thanks for the advise guys, I really appreciate it, later.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
jaridjohn
Oct 5, 2015 07:01 AM
