Stumble and surging
Old Oct 13, 2003 | 09:25 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Stumble and surging
Hey Ya'll,
First of all, I did some searching. I just am curious to what most of you would do to determine where the stumbling is coming from, spark or fuel.
When cold and in open loop, I have no problems. Feels great. When the engine warms up and goes into closed loop, heated 02, the car has a mild stumble/hesitation off idle and doesn't really let up until about 2200 rpm. Tonight I played with the low rpm VE table, added some fuel, and it got a little better. Then I added some timing in the same RPM and MAP area and it got a little better still.
I have also had a slight surging when in part throttle cruise since the new engine. Its not bad, but I don't like it. I feel it at about 2500 rpm. If I cruise higher, 2800+, I don't feel anything.
What are some thoughts? As for the stumble, I think I am lean down low because I stay out of the gas for now, since its new and untuned, and I checked the plugs today and they look a bit lean. They are pretty new, changed Sat. afternoon.
Thanks in advance...
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
banksGTA
Sep 13, 2015 11:56 AM
