Stock Spark table q's
Old Oct 29, 2003 | 08:26 PM
lykan's Avatar
Ok, from what I gather from reading (I may be way off) When you nail the throttle to the floor, your timing should advance.. I was looking at my stock spark table. I noticed the higher the MAP value (more throttle?) at low RPMS, the less timing the table allows.
for example at 100 kpa, and 400 rpm. its actualy taking out .7 degrees of timing.. why is this? Im feeling kind uneducated here., i had assumed when you put the pedal to the floor, the timing would advance to allow for more power on accel...maybe its for fuel economy and longevity of the motor?
I know im probably asking for along complicated answer.. but if your willing to type it up, I am willing to read..if you have anything to add to help my understanding of map vs timing I would sure appreciate it.
Just for giggles here's my table (bone stock 350 with tbi mods)
Code:
  RPM                                                MAP (Kpa)
         20    25    30    35    40    45    50    55    60    65    70    75    80    85    90    95    100
   400  20.0  20.0  20.0  20.0  20.0  18.3  17.2  12.3  11.3   9.1   6.3   4.2   3.2   2.1   1.1   0.0  -0.7
   600  20.0  20.0  20.0  20.0  20.0  18.3  17.2  12.3  11.3   9.1   6.3   4.2   3.2   2.1   1.1   0.0   0.0
   800  20.0  20.0  20.0  20.0  20.0  20.0  20.0  16.2  14.1  10.2   9.1   5.3   4.2   2.1   1.1   0.0   0.0
  1000  20.0  20.0  20.0  20.0  20.0  20.0  20.0  18.3  15.1  13.0  10.2   7.0   5.3   3.2   1.1   0.0   0.0
  1200  20.0  20.0  20.0  20.0  20.0  20.0  20.0  18.3  16.2  14.1  11.3   9.1   7.0   5.3   3.2   2.1   1.1
  1600  21.1  21.1  21.1  21.1  21.1  21.1  21.1  19.0  18.3  15.1  13.0  11.3   9.1   7.0   5.3   4.2   4.2
  2000  22.1  22.1  22.1  22.1  22.1  22.1  22.1  20.0  19.0  16.2  14.1  12.3  10.2   9.1   7.0   6.3   6.3
  2400  23.2  23.2  23.2  23.2  23.2  23.2  23.2  22.1  21.1  18.3  16.2  14.1  12.3  11.3   9.1   9.1   8.1
  2800  25.3  25.3  25.3  25.3  25.3  25.3  25.3  23.2  22.1  19.0  17.2  15.1  13.0  12.3  11.3  10.2   9.1
  3200  26.0  26.0  26.0  26.0  26.0  26.0  26.0  24.3  23.2  22.1  18.3  17.2  16.2  14.1  13.0  12.3  11.3
  3600  27.1  27.1  27.1  27.1  27.1  27.1  27.1  26.0  24.3  22.1  20.0  18.3  17.2  15.1  14.1  13.0  12.3
  4000  30.2  30.2  30.2  30.2  30.2  30.2  30.2  30.2  25.3  23.2  21.1  20.0  19.0  17.2  17.2  16.2  15.1
  4400  30.2  30.2  30.2  30.2  30.2  30.2  30.2  30.2  26.0  24.3  22.1  21.1  20.0  18.3  18.3  18.3  17.2
  4800  30.2  30.2  30.2  30.2  30.2  30.2  30.2  30.2  26.0  24.3  22.1  21.1  20.0  18.3  17.2  16.2  15.1
  5200  30.2  30.2  30.2  30.2  30.2  30.2  30.2  30.2  26.0  24.3  23.2  22.1  21.1  19.0  18.3  17.2  16.2
  5600  30.2  30.2  30.2  30.2  30.2  30.2  30.2  30.2  26.0  24.3  23.2  22.1  21.1  19.0  18.3  17.2  16.2
  6000  30.2  30.2  30.2  30.2  30.2  30.2  30.2  30.2  26.0  24.3  23.2  22.1  21.1  19.0  18.3  17.2  16.2
Old Oct 29, 2003 | 08:46 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Stock Spark table q's
[/code]
Lean mixtures are slow to burn so you need more time, ie advance for them to burn so in cruise mode when the engine is running lean you need alot of advance.
WOT developes alot of heat, and the mixture lights easy, so not as much timing is needed.
The only time the engine sees the 100 K/Pa 400 entre is went the engine first starts as is gaining speed from the starter spinning the engine to actual idle RPM
Long explainations made short.
HTH
Old Oct 29, 2003 | 10:51 PM
18436572's Avatar
Car: 69 Camaro
Engine: 355 SBC
Transmission: Glide
Axle/Gears: 4.88 full spool
WOW
I've been flogging cars for along time now and I have never understood timing as well as I do now.
Thanks Grumpy, very well explained
ED
Old Oct 29, 2003 | 11:11 PM
lykan's Avatar
Thankls for the understanding grumpy, i figured you'd chime in now if I can just figure out how to apply it to my tables.
Azrael91966669
25
Jun 20, 2017 04:04 AM
djmarch
Aug 19, 2015 12:07 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
