trouble with pp2
Old Nov 7, 2003 | 01:20 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
trouble with pp2
I'm using version 1.93 in windows and I can't get the software to program the 27sf512 prom from 0C300 to 0FFFF with out it giving me a file that is 64Kb in size.
Old Nov 7, 2003 | 07:53 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: trouble with pp2
A 27SF512, takes a 64 Kb file to fill.
You should be able to set the start address, the start of buffer, and end of buffer down in the middle of the page.
Old Nov 7, 2003 | 09:28 PM
eric305TPI's Avatar
I did set the start and end addresses correctly but when burned it causes it to go into limp-home mode. If I stack the bin it does not go into limp-home. I'm running XP-Pro if that makes a difference. I would like to be able to burn without stacking the bin.
Old Nov 8, 2003 | 07:37 PM
eric305TPI's Avatar
Just putting it on top
Old Nov 8, 2003 | 11:33 PM
Chevota's Avatar
Car: 1970 Toyota FJ55, 1971 Datsun 240z
Engine: 350 chevrolet both
Transmission: 700r4, and t5 respectively
I wrote email to the makers of PP2, and what I got from them was that the design of the 27sf512 did not allow for writing to just a portion of the unit. You could only do a complete burn, or nothing at all. I am not sure if this is true, but it does sound very possible. I too didn't want to do the bin stacking, but if you use the bin stacker in tuner pro 3.0 it isn't that bad. It is pretty quick.
I want to ask how many times it takes you to get a good burn to the eeprom? I am using WinXp pro and the PP2 as well. I am running on a 600 mhz PII in a gateway laptop. I have been having varying results when burning to this eeprom type. Sometimes it takes me 3, or 4 times to get a good copy onto the eeprom. PP2 will come up with errors while doing the write. And sometimes it has problems doing the erase. But in the end I always get a good copy - It just takes many attempts. I have turned off all power saving functions in the bios and in the OS. And I have no other programs running in the background. Anybody have experience with this???
Thanks,
Marcello
Old Nov 9, 2003 | 10:12 AM
eric305TPI's Avatar
I have not had a problem yet when erasing or programming the EEPROM. I'm running it on a 2.2Ghz 1Gb RAM Athlon(Barton Core) WinXP Pro machine without closing any of my background programs. I have not tried it on my laptop which is a 300Mhz PII with 96Mb Ram with 2KPro on it. Will post results with that machine when I use it.
mrbird
Oct 20, 2015 03:43 AM
Lmancha96
Sep 25, 2015 08:11 PM
HikoriYami
Sep 21, 2015 07:11 PM
BWilcox
Sep 20, 2015 12:19 PM
eduardosac
Sep 16, 2015 02:18 PM
