knock sensor
Old Nov 8, 2003 | 04:56 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
knock sensor
I am getting false knock so i turned of the knock sensor diagnostic in the chip but it is still pulling timing and showing knock. do i just need to change the max knock retard per rpm and map in the chip to fix this or am i doing something else wrong
Old Nov 8, 2003 | 08:15 PM
87_TA's Avatar
Knock retard vs. RPM in PE for WOT stuff. make zero.
Knock retard vs. map for others.
Though I may add it is better to fix Problem rather than disable.
But if you absolutely have to..there it is.
Old Nov 9, 2003 | 12:13 AM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
thank you. I thought that is what i should do but i wanted to make sure before i did it. I have been fighting this false knock for awhile now and I have given up.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
