using the stock TBI computer controled distrib with a carb
Old Nov 16, 2003 | 10:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
im going to be switching to a new friends TBI motor to a carbed motor soon...
i believe it was pablo that had found a way to make the computer control just the spark..
any specifics on how to do it? bins i need? ect?
i can have another friend burn a prom, thats not a prob.
if i just dropped it in there as is, does it still run the regular spark tables? even if it doesnt see a TPS, AIC, injectors, ect...? what about the MAP? would it still use that?
any help or links other then to here would be great.
Old Nov 17, 2003 | 01:33 AM
JPrevost's Avatar
Car: 91 Red Sled
Wasn't pablo, it was RBob.
http://www.diy-efi.org/gmecm/papers/
It's under "Papers by Robert Rauscher"
Old Nov 17, 2003 | 04:11 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Uh yeah there there wasnt anything to discover and I certainly wasnt the first to do it.
Basically take off the tbi unit and bolt on whatever you will, make sure you reconnect all the sensors, for TPS I just took a zip tie and held it at a setting between what would trip a high tps and low tps code. you wont get WOT spark advance though and probably a few SES lights so id suggest learning to program chips.
If you do and get into tuning youll find yourself longing for fuel injection again anyways though.
Old Nov 18, 2003 | 11:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you decide to use the ecm to do this then make sure you take the time setup the timing table properly. My engine ran like poop with the stock table. Had lots of knock at mid map/rpm values adn not enough timing at WOT. I dont know how it is with the later l03 ecms but with mine, after each knock count, i used to have to wait 4 seconds before the timing would be fully restored. The ecm had a very aggressive routine for handling knock. This means taht its adventagious to make sure you dont have detonation otherwise youll have erratic performance.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
Thirim
Aug 9, 2015 06:19 PM
