Open loop at idle
Old Nov 19, 2003 | 11:36 PM
ULTM8Z's Avatar
Open loop at idle
How can I deliberately make the ECM go into open loop at idle speed (even when fully warmed up)? I only have access to the CATS Tuner, but I can't see any options for this.
Old Nov 19, 2003 | 11:59 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Set the coolant temp for closed loop to a very high value like 150*C. However, you will be in open loop all the time.
Old Nov 20, 2003 | 08:23 PM
JPrevost's Avatar
Car: 91 Red Sled
Which ecm do you have? There should definatly be an "if in idle, open loop." I thought there was this option for most of the ecms. If not, how hard could it really be to set the ecm into open loop whenever the idle flag is set.
Old Nov 20, 2003 | 08:47 PM
ULTM8Z's Avatar
It's a 7730 ECM. I looked all through the tables but couldn't find anything to do this.
Old Nov 20, 2003 | 08:56 PM
funstick's Avatar
if youve got the ve table the way you want it ust set the loe blm limit upto 128. that will stop it from pulling fuel but still keep the lean correction working
Old Nov 21, 2003 | 03:51 PM
Gary Anderson's Avatar
How about idling in PE mode?
Regards,
Gary Anderson
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
CORV3TT3
Aug 23, 2015 11:26 AM
beast94
Aug 20, 2015 06:44 AM
